Fuel Pressure Gage
Stumper
6:36 AM
Bandana, NC
Ok, not specifically B body or even Mopar for that matter but I have a question. I've had a heck of a time with fuel pressure gages over the past few years. They just don't seem to hold up for long. I have admittedly, messed with the plumbing and guages on the car a bit trying to come up with a system that works for me but this is getting expensive. I recently gave up on trying to make a pressure isolator for an inside gage work properly and took it back out. I returned to just a gage on my regulator that fed the rear bowel. Then I went an bought a duplicate gage to install on the front bowel side of the regulator and the two damn gages read differently, I have noticed that the two do not "zero" to the same position - and the one that reads higher at zero also reads higher under pressure. Is there some way to adjust these things to zero properly or do I need yet another new gage??? Both are the same model Autometer gages.:angry1:
autometer gauges work fine. either a electric one for inside of the car or a mechanical one for outside on cowl. never had a problem.
which carbs are you running. maybe your float levels are too high. i had that problem also. drop down floats a little and see if it helps.
I can check them but how would the level impact the pressure gages? The gage that reads higher is the older gage and it also shows a higher needle position when the car is turned off.
disregard my response about floats. i thought you were having issues when the car was running.
whose gauges are you using?
i only use autometer. sport comp, ultra light,
my 63 plymouth has a 40 year old sun fuel pressure gauge and it works great.
Both of the gages are Autometer mechanicals. The new one I just bought the other is maybe a year old. The last one I had was one of the Holley gages and it only lasted a year... I am wondering if there is a way to recalibrate the needle position on them?
disconnect the fuel line to it and let it sit overnite and see if they go to 0 on their own.
Thats a thought. I suspect it won't go all the way down but its worth a try.
Are the guages dry or are they liquid filled? If there liquid filled that could be your problem.
I started using a shock eliminator on my guages recently, it seemed the initial blast of pressure on the guage was messing them up, I actually found about this on a diesel engine forum. Not sure if shock eliminator is the official name of the part but it gives the general idea.
You can adjust the needle position but if you want to calibrate it you will need a very high quality gauge to use as a reference. These are bourdon tube gauges and the needle is connected to a gear mechanism that is attached to the bourdon tube through a link. It won't take much to ruin it so be careful.
Everything you wanted to know about gauges but were afraid to ask -
http://en.wikipedia.org/wiki/Pressure_measurement
Is there an easy external adjustment? I see a small screw on the bottom of these gages.
STUMPER, did you try what i said and disconnect the line from the gauge and let it sit overnight.
somethings wrong if it keeps happening to all your gauges. mine never had 1 single problem ever.
