David Womby
Happy New Year!
New Year: new problem.
My electric fuel pump was installed upside-down when I got the car and very noisy. Also, the filter never seemed full of fuel despite the pump and filter being mounted below the level of the fuel tank bottom.
I remounted the pump in the correct position (upright) and it's very quiet now BUT the filter still never stays full. I attached a pressure gauge to check the fuel pressure and things are behaving oddly. With the engine idling, the gauge sits at 2-3psi most of the time and the filter looks practically empty but every so often the gauge will jump to about 7psi for a moment or two simultaneously with a surge of fuel appearing in the filter. You can see this in this video (sorry for the poor quality) - at 27secs it drops to 2psi, at 57secs it jumps to 7psi and fuel fills the filter then it immediately drops again and the next surge to 7psi comes along at about 1min 27secs. Fuel pressure video
Any ideas what's going on here? I would be expecting to see the filter full all the time and the pressure constant. Is the pump/regulator toast? Thanks
David
David
