- 4:15 PM
- Apr 13, 2012
- Granite Bay CA
I was having some fuel starvation issues so I pulled my Holley mechanical pump and installed a Carter. the Holley did deliver a steady 6-7 lbs of pressure. This Carter is between 10 and 11. The way I see it, I'd need to install a regulator to keep things kosher.
I'm thinking of installing this one:
http://www.summitracing.com/parts/aei-13201/overview/
It is listed as being a "Non return type" but I wonder if that is because it only has 2 ports. My proposed arrangement is to place the regulator behind the feed line to the secondaries. The "inlet" would be near the back of the engine and the "outlet" would be plumbed into the 1/4" vent line that is currently UNused and capped off.
I'm no expert on this stuff but it seems that if the unit is regulated to a number above what the pump is making, the excess pressure would flow out of the "outlet" port and back to the tank.
Let me know what you think.
