cbodybob
I did hit oil LOLKeep drilling cbodybob, hopefully you never hit oil! 440'
Hope you never wreck it. It will collapse around you like crumpled paper.View attachment 1246594 30 hours on this door alone. A little over 10 pounds. 70 grams from trimming the thick shoulders on the upper hinge. I still need to lighten the bolts. The door brace was a bit over 7 pounds. 3138 pounds when it was last scaled in October 21. View attachment 1246592View attachment 1246593
NoHope you never wreck it. It will collapse around you like crumpled paper.
I thought about that, but still would have needed to drill some small holesWhy not go they that hinge with a hole saw instead of all the little holes
My front shocks don’t have them but I think the rear does.Another place that is overlooked, cut off the dust shields from shock absorbers if they have them. I took them off my shocks, saved 1/2 pound per shock on the front and 1 1/2 pounds per shock on the rear, 4 pounds total.
Jus sayin......
This car left the factory at over 4000, it’s just over 3100 currentlyWith a lighter door, the hinges don't need to be so 'hefty'. On my 65 Belvedere, the door hinges went from 6.2 lbs/pair to 3.4 lbs/pair including bolts. The pounds add up, look everywhere.
Elbow grease + saws = lightness.
Thank you. And that’s with a 10 pt cage & two drive shaft loops & a big block.3100 lbs is no small feat with the later cars. That is an amazing accomplishment.
—-View attachment 1246594 30 hours on this door alone. A little over 10 pounds. 70 grams from trimming the thick shoulders on the upper hinge. I still need to lighten the bolts. The door brace was a bit over 7 pounds. 3138 pounds when it was last scaled in October 21. View attachment 1246592View attachment 1246593
Yep that’s the scales at Galot Motorsports Park. Same one the Pro Mods roll across—-
That is some serious weight reduction going on over there. Is that 3138 with the car in race form? A couple of months ago my hood hinges got similar treatment to your door hinges.
NiceThe hinges on my 65 Belvedere.
Definitely should have been an intervention….30 years ago. 1992 to be exact LOLUhhhh, Bob?
It almost feels like an intervention is needed here...
You're like a termite for metal.
