erikcroissant
Good running mopar 400. This engine was in my 68 Coronet when I bought it. I just swapped in a new motor, so I’m selling this one. I drove it into the shop before swapping the motor, it runs good, done a few 100+ miles trips no problem.
I stole some parts to put on the new motor, so it’s more or less a long block. Original intake, valve covers, and a valley pan are held on hand tight with no gaskets. I have the original exhaust manifolds and hardware.
Engine has a bit of coolant, no water pump. Temps were always perfect, never overheated. Oil is full with new filter. My gauge always read 70-80 psi, so do with that what you will. I never had a single issue with this engine.
You need a carb, distributor, water pump, front accessories, and some new hardware, gaskets etc and you’re good to go. Or you can build a nice stroker motor.
I have videos of it running and will upload more pictures tomorrow.
I’m in the Bay Area CA
$500
I have an engine hoist to put it in your truck bed, and you can keep the wood engine stand. It works ok.
$500
