Not sure i know the difference between electronic and GPS?I considered a GPS speedo when I built my gauge cluster, but I settled on an AutoMeter electronic speedo.
It was my understanding that the the GPS speedo can be kinda' weird when you first start the car and you have to find a good spot for the antenna. Those issues might be overblown, but the electronic speedo was cheaper and once it's calibrated, it just works. Calibration just requires you to measure a two-mile long route, activate calibration mode, drive the route, then push a button.
GPS triangulates off of satellites, electronic requires a transducer on the trans or driveline. A nice feature of GPS is you can change to an overdrive, change the gear ratio or tire size without needing to recalibrate the speedometer.Not sure i know the difference between electronic and GPS?
You know he wants the GPS that the insurance companies can track how fast these driving so they can charge you more
Pricey buggers !!!!
What car are you using it for?Anyone using one? Recommendations?
68 b bodyWhat car are you using it for?
