ground cable location on engine to battery on 383
7:49 AM
tennessee
we are hooking up the wiring harness in the 69 coronet and we cant find any pictures or diagrams of where it goes. any help is appreciated! Thanks in advanced
I think its to the head, where the throttle return spring bracket is, but not positive. I think there's also a ground strap from the firewall to the motor as well on the back opposite end. Someone with a correct resto will chime in.
Yup ^^ it goes cable, throttle return spring bracket, bolt in that order starting with the ground cable first. That is why the negative cable has overspray of engine color halfway up the cable or so. Was all painted from factory as one when engine was done.
