Black is the color that shows the most irregularities when painted and a guide coat would be very beneficial to keep it as smooth as possible . . . Good luck !
I agree you want something to contrast like white, light gray, yellow, ect for black primer. I've used spray paint before, works just fine but make sure it's something that sands easy and doesn't attack the primer. I sprayed a dusty coat (not wet) on then wet sanded it all off with a block.
