rustytoolss
My 62 Plymouth has an aftermarket Power brake system. The pedal is hard, the car is not safe to drive. I've checked the booster with the pedal drop test (it check good). I have 16-18" vac. Was working on it today. Remove MC from booster (8" daul) used screw driver to operate the MC piston. The front chamber(rear brakes) would shoot up a stream of fluid/ but did not see any movement from the rear chamber (front brakes) .
I could use some help here. The PO told me that the brakes never work right since the Power system was installed...He's right.
