SOLD Harland Sharp 1.5 Ratio big block
HemiBound426
6:35 AM
Indianapolis, IN 46202
Feedback: +0 / =0 / -0
Harland Sharp 1.5 big block rocker arms. Less than 3000 miles on them. I upgraded to trick flow 270 max wedge heads. These are for standard steel or aluminum heads. $475, located in Indianapolis, IN and I'll gladly make a detailed video so you can get a clear look at the condition before purchasing.
Is it correct that these rockers will work on the 270 Trickflow heads?
They’ll work but roller contact on valve will be offset about .030” towards exhaust side with Eddy/TF/Stealth heads. You may also have to clearance heads for pushrods with Aluminum Heads.
So that off-set is for standard factory heads? What is the rocker part number?
Those appear to be 2 different set of rockers.
Pic #1 blown up looks like stock rockers. Pic #2 not so much
