header - starter touching
Mopar Exhaust Systems
  1. charger10
    charger10 Well-Known Member
    117
    43
    Nov 28, 2018
    idaho
    Local Time:
    3:25 PM
    I had previous posted that I had put my engine in with doug headers and everything fit. but trying to put steering shaft in , I saw that the header and starter were touching at the front of starter. what should I do??
  2. 91r/t
    91r/t FBBO Gold Member FBBO Gold Member
    1,765
    2022
    May 7, 2011
    Buffalo, NY
    Local Time:
    4:25 PM
    Mark where it touches the starter with a couple sharpie dots when mounted, then take it off and ding it to clear if it affects the mounting of the headers. Or you can leave it it bolts on and just barely touches, but it's gotta make heat in the starter and shorten its life. Not much of a choice otherwise. I have seen some squeeze a ding in with a clamp and a flat stock on the opp side you want the ding if you can fit it in there.
  3. Don Frelier
    Don Frelier FBBO Gold Member FBBO Gold Member
    1,869
    1921
    Oct 11, 2016
    Ionia, NY
    Local Time:
    5:25 PM
    Is it a mini starter? If you already have a small starter then mark it remove a and take a heavy pipe and give it a dent by hitting the pipe with a mash hammer
    • Like Like x 2
    • odcics2
      odcics2 Well-Known Member
      813
      635
      Jul 25, 2013
      MoTown
      Local Time:
      5:25 PM
      You may want to fashion a heat shield for the starter...
      • Agree Agree x 1
      • charger10
        117
        43
        Nov 28, 2018
        idaho
        Local Time:
        3:25 PM
        the starter is regular size stock
      • khryslerkid
        khryslerkid FBBO Gold Member FBBO Gold Member
        19,702
        28473
        Mar 10, 2010
        Hanover, Pennslyvania
        Local Time:
        5:25 PM
        Get a '90 ish Dodge Dakota mini starter. You'll love it!
        • Agree Agree x 6
        • MoparLeo
          MoparLeo NRA PATRON LEVEL LIFE MEMBER FBBO Gold Member
          643
          475
          Nov 24, 2015
          Moreno Valley, So California
          Local Time:
          2:25 PM
        • Cranky
          Cranky Banned Staff Member FBBO Gold Member
          19,915
          16007
          Dec 4, 2009
          Pasa-getdown-dena Texas
          Local Time:
          4:25 PM
          Wow....didn't know anyone was still using those. The mini's have more power too but you won't get that old sound that the original starters make but I found I don't miss that sound anymore lol. Also, Mom made two different starters....one was larger so if you have the large starter, you might can find the 'short' one instead. The difference in horse power is about .3 between the two. The smaller motor produced 1.5 hp. The shorter starter has a motor length (measure the black part only) of about 3 1/4" and the longer starter is about 3 3/4" long. The bigger starter usually spins faster than the small though. The small motor starter is more common so you might already have that one installed.
          • Agree Agree x 1
          • odcics2
            813
            635
            Jul 25, 2013
            MoTown
            Local Time:
            5:25 PM
            Let this be a lesson to all you youngsters out there - Hooker Headers fit with the stock starter.
            • Thanks! Thanks! x 1
            • Cranky
              19,915
              16007
              Dec 4, 2009
              Local Time:
              4:25 PM
              Had a set of Hooker Super? Comps on a 71 340 Cuda and you could even pull the starter out without loosening the header. It was the smaller stock 1.5 hp starter though and you had to hold your mouth just right to get it out and then back in but it was doable.
              • Like Like x 1
              • Steve009
                Steve009 FBBO Gold Member FBBO Gold Member
                634
                552
                Aug 2, 2016
                Ottawa
                Local Time:
                5:25 PM
                even my mini starter hit my Dougs headers. quite a few smacks with hammer, heat, and impact socket did the trick.
              • MoparLeo
                643
                475
                Nov 24, 2015
                Local Time:
                2:25 PM
                TTI...........
                • Agree Agree x 3
                • Cranky
                  19,915
                  16007
                  Dec 4, 2009
                  Local Time:
                  4:25 PM
                • khryslerkid
                  19,702
                  28473
                  Mar 10, 2010
                  Local Time:
                  5:25 PM
                  Mine didn't! :p
                • charger10
                  117
                  43
                  Nov 28, 2018
                  idaho
                  Local Time:
                  3:25 PM
                  not so young at 67yrs. but 1st headers I ever had. it is the long stock starter. guess I will try to get header and starter out.
                • Cranky
                  19,915
                  16007
                  Dec 4, 2009
                  Local Time:
                  4:25 PM
                  Oh man, my first car got headers as soon as the poly teen came out and a mild 383 went in and probably more than 1/2 of the cars I've owned had headers. Even invested in a very large flat file to make sure the gasket surfaces were good. Also make sure the head has a good surface for the gasket. Doing that help puts you ahead of the curve on leaks!
                  • Agree Agree x 1
                  • odcics2
                    813
                    635
                    Jul 25, 2013
                    MoTown
                    Local Time:
                    5:25 PM
                    Good Luck!
                  • khryslerkid
                    19,702
                    28473
                    Mar 10, 2010
                    Local Time:
                    5:25 PM
                    One set I had on a '64 with a 383, had the old starter, that's all there was back then. Remembered having to have the header completely loose, stick the starter halfway in, then contort the header a little more, then get the starter a little bit closer until it all came together. Some will even have the motor mount loose with a jack under that side. Good to have someone there to help hold the loose header where you need it while stuffing the starter.
                    One thing that really makes it easier is to pull the steering column. Not having the steering shaft there really makes it easier. Only thing is pulling the steering column out is a little time consuming but it will help.
                  • 1967coronet
                    1967coronet FBBO Gold Member FBBO Gold Member
                    1,127
                    1331
                    Jun 19, 2014
                    Iowa
                    Local Time:
                    4:25 PM
                    Im still running the full size long starter also. with Schumacher tri Ys :D
                  • Steve009
                    634
                    552
                    Aug 2, 2016
                    Ottawa
                    Local Time:
                    5:25 PM
                    Lucky! Most frustrating 5-6hours of my life! My First time installing headers on a b body.
                  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                    By continuing to use this site, you are consenting to our use of cookies.
