- 12:53 AM
- Oct 13, 2025
- geneva indiana, shelby county
I have a 65 satellite with a poly 318. I have access to a 360 magnum engine. are there any headers that would fit with power steering?
thanks for the TTI info.TTi makes headers for the poly that work with p.s. So it depends on the port layout compared to conventional small block heads.
I meant for the 360 conversion.TTi makes headers for the poly that work with p.s. So it depends on the port layout compared to conventional small block heads.
Good question. I don't see any listed for that combo on TTI's site but I may have overlooked the application. 273's were available in early B bodies but that is the only LA engine available. And, I think in 65 only.I have a 65 satellite with a poly 318. I have access to a 360 magnum engine. are there any headers that would fit with power steering?
They're about as similar as a Hemi to a Wedge.I can't answer your question,however aren't the magnum manifolds supposed to flow fairly well?
Are the exhaust ports different from a poly to an LA or magnum head?
thanks to all that answeredProbably would be best to give TTI a call to make sure they make something that fits your application. Their tech support has always answered my questions.
I could not find TTI online.thanks to all that answered
