Headlight/brake Light issues
Uthman Clark
3:35 PM
Montgomery Alabama
so, in my 72 Satellite, my brake lights do not function even though my rear lights will come on if i cut them on. My reverse lights also don’t work. My headlights only work if the high beams are on. Flashers work and all other lights come on.
I had brake light issues with a couple of these and the culprit both times was the turn signal switch in the column.
Headlight issue might be the dimmer switch.
Agree
Also, check ground
