44070dart
- 12:58 AM
- Jul 7, 2009
- right behind you
turn on my headlights and all the lights work except the headlights.. the harness connector from the bulkhead looks a bit melted at the secondary connection near the battery... is there some way to disconnect the harness at the connector by the battery location and hot wire the head lights to see if that connector from the bulkhead is bad..I got the front marker light to work like that by touching a hot wire to one of the connectors, but not headlights.... you can tell from question I'm not a wiring genius.. also the headlight doors open fine.
