Help A100 seats
300
3:10 AM
Canada
Hi, Putting A100 buckets in my 65 Satellite,
Do you use the 2 outboard holes in floor pan,
Got mine in that location seems close to front etc
I can still sit, and work petals etc( I'm 6ft)
Can't move them back cause of brackets with floor contour
Also Drivers seat is only 2". From door panel
This might be the way it is, Just wondering
Any pics and measurements would be great
Thank You
I am looking at the same thing on my 65 Belvedere. Mine originally had a bench seat, so the 2 outer holes were for the bench, but using them put a bucket seat too close to the doors. Look closely at your floor pan. I have 2 dimples in the floor sheet metal that line up the bench holes, but are closer to the trans tunnel. I think those are for bucket seats. Since the A100 seats on the aluminum brackets are fixed in place, you will want to get the seat placement comfortable before drilling holes. I may need to move mine back a bit to get leg room.
So, I guess not to use outward 2 holes, now to move seat back it will over hang the hump, I'll keep playing,
Anyone got some measurements from existing 2 outboard holes, to new ones they made to move seat closer to Trans hump, and say from gas petal to front of seat ( not seat bracket)
Much appreciated
I did go go on link alfalfa, and that 43" seems to far back, I could be wrong
I've got A100,s in my 64 plymouth.......im 6 foot 2 and did use some existing holes.......i can take some measurements. Tomorrow for you..i did have to fab up a couple aluminum blocks to get a correct. Sitting of the seat frame....jay
