SOLD hemi injectors / lenco's / scatter shield / valve covers & misc
chooch
4:28 AM
pixburgh,pa
Feedback: 7 / 0 / 0
Wts-
-Used polished 426 hemi Hilborn injector never ported & doesn't appear to be milled. comes with the matching polished pump that will need rebuilt since doesn't turn freely but comes apart would be good for a core rebuild or dummy mock up to complete the look. injector is missing the barrel valve, lines & nozzles basically a bare unit with 9" stacks, butterflies & shafts that move freely would be perfect for a EFI conversion. these parts have been sitting for a while & will need cleaned up again but aren't bad the stacks show some slight signs of rust peppering but should polish up $1000. + shg
-Enderle complete 426 hemi injection unit appears to never been bolted to a motor or had a fuel line hooked up not ported or milled everything is in great shape & moves freely with 6.75" stacks that had some slight surface rust on the center riser that easily cleaned up & just need a light dusting of spray grey or detail to make perfect. also included is a hilborn 150 pump that moves freely & seems to have no noticeable issues but will still need gone through. $1800+shg
- Lenco CS1 3 speed with reverser & air shift pods, input shaft, reverse handle, blanket & some type of adapter plate. seems to be in working condition with no obvious damage or repairs spins freely but still should be gone through $3000+shg obo
-Lenco CS1 3 speed with reverser & air shift pods also slider cradle seems to be in working condition with no obvious damage or repairs spins freely but still should be gone through $2500+shg obo
-will be listing soon 10/66 cast std bore hemi with heads, valve train, crank, rods & pistons
Can bring to columbus if prepaid.
