Here is the Custom Cam/Hydraulic Flat Tappet
Engine, Trans & Driveline
  1. FlagCraig
    FlagCraig Well-Known Member
    526
    500
    May 19, 2015
    Tennessee
    Local Time:
    6:59 PM
    What do you all think?
    It's is going in 67 GTX and it will be a street car (shows and cruising). We are getting closer. All parts are in and ready to proceed.
    Might do a pass or two at a track but no plans to race.
    I am not against changing cam if needed. It was recommended by the Mopar/Engine shop.
    236/236 Duration
    .364/.364 Lift
    108 Degree Lobe Separation
    +3 Advance on Cam
    Going in:
    505 Stroker (67 440)
    Ported and Machined 915 Heads (Original)
    Automatic 727 (rebuilt)
    Rear End Gears 3:55
    Headers TTI
    Torque Converter Stall 3200-3500
    Carb 770 Holley Avenger
    Holley Street Dominator Intake
    Thanks for thoughts.
    • Like Like x 1
    • oldbee
      oldbee FBBO Gold Member FBBO Gold Member
      9,508
      9533
      Oct 15, 2011
      NE Ohio
      Local Time:
      7:59 PM
      Duration at .050" lift? Might be really nice!
    • texas69bee
      texas69bee Well-Known Member
      1,650
      1083
      Dec 3, 2013
      texas
      Local Time:
      6:59 PM
      Is the lift really .364?
    • vintage chromoly
      vintage chromoly Well-Known Member
      2,106
      3832
      Nov 13, 2010
      ohio
      Local Time:
      6:59 PM
      Lobe lift.
      • Thanks! Thanks! x 1
      • moper
        moper Well-Known Member
        1,044
        639
        Sep 25, 2014
        Eastern CT
        Local Time:
        6:59 PM
        That's the lobe lift. Multiply by rocker ratio for lift at the retainer.
        What is the static ratio? Which pistons are being used?
        • fratzog lover
          fratzog lover Well-Known Member
          3,714
          5320
          Apr 10, 2014
          Northeast Alabama
          Local Time:
          6:59 PM
          .546 lift. Any idea what the heads flow?
        • mentor70
          mentor70 Well-Known Member
          566
          219
          Oct 17, 2014
          walnut, california
          Local Time:
          4:59 PM
          kinda small for a 500 CI (duration) lift is OK, but i and i wouldnt even consider running iron heads on a 500 either.
        • wyrmrider
          wyrmrider Well-Known Member
          2,613
          1018
          Aug 26, 2014
          los angeles
          Local Time:
          4:59 PM
          Need Head FLows (ported, large ex valve? larger intake etc), stroke and rod length, compression ratio
          without the duration no one can tell if it would work or not
          .050 is for degreeing in the cam, not to spec one
          what rockers and did you do B3?
          solid, hyd, roller?
          OK OK I see the thread title
          still need to know the seat duration- most likely at .006 but call it out
        • FlagCraig
          526
          500
          May 19, 2015
          Tennessee
          Local Time:
          6:59 PM
          Okay additional info:
          -.50" for Intake and Exhaust Duration.
          -Eagle Forged Crank 4.250 stroke 8 bolt.
          -Forged Piston and Ring Set 4.350x4.25"
          -Rod Bearing Narrowed H Series 2.200"
          -Eagle H Rods 7.100" x .990" x 2.200"
          -Compression high 9's.
          -Heads were given a "racing" valve job. Installed 8 no lead seats
          and 16 bronze valve guides.
          Valve Guide .343 x .502 x 2.125
          Intake Valve 11/32" Stem, 2.14" Head
          1.81" Exh Valve
        • IQ52
          IQ52 Well-Known Member
          1,706
          2305
          Aug 2, 2011
          Idaho
          Local Time:
          5:59 PM
          Yes, yes. Time and again it has been documented that those old iron heads just cannot be made to work on big cubic inch engines.
          Wait.........WHAT?
          If you scroll down to the third engine in this article, you can see the results of 906 iron heads on a pump gas 500" engine run on Comp Cams' dyno.
          https://www.hotrod.com/articles/mopp-1203-the-amsoil-mopar-muscle-engine-challenge/
          O.P. You already own the cam and it's in the engine? Run it. If you don't like it, then change it.
          • Agree Agree x 1
          • PRHeads
            PRHeads Well-Known Member
            1,195
            1545
            Aug 31, 2018
            So. Burlington Vt
            Local Time:
            7:59 PM
            Not what I woulda used...... but not way different either.
            It should run fine.
            • moper
              1,044
              639
              Sep 25, 2014
              Eastern CT
              Local Time:
              6:59 PM
              IMO, the cam's a little small. It sure doesn't need any advance built into it. I see that a lot on these long stroke engines and it's a total waste IMO. These engines are not soft down low. They don't need it.
            • Heimedw
              Heimedw Well-Known Member
              263
              104
              Aug 23, 2014
              Ontario
              Local Time:
              7:59 PM
              The best thing you can spend money on in any engine build is the heads! They are the biggest factor on how the engine will perform. Game changer for me watching engine masters on motor trend. They did a test on a 408ci ford small block with this little bitty cam to test if heads could be to big and the results still blows me away! AFR make amazing heads by the way wish they would make some mopar stuff!
              • Agree Agree x 1
              • FlagCraig
                526
                500
                May 19, 2015
                Tennessee
                Local Time:
                6:59 PM
                Keeping the 915 heads on the car was important to me. They were special heads only used on the 440 in 1967 (as we all know). I'm not looking to race this car just a good strong rebuild. Anyone can say they have aluminum heads (many suppliers) but the 915's are rare.....and original to the car. And if done right and matched with some of todays advances on other parts/accessories can give good power. If it puts me back in the seat now and then and lets me do a few burnouts I'll be satisfied.
                • Like Like x 2
                • IQ52
                  1,706
                  2305
                  Aug 2, 2011
                  Idaho
                  Local Time:
                  5:59 PM
                  Run the cam and heads you have. If this Mopar/Engine shop has the foggiest notion what they are doing, you'll be fine.
                  • wyrmrider
                    2,613
                    1018
                    Aug 26, 2014
                    los angeles
                    Local Time:
                    4:59 PM
                    I run 915 heads on my motorhome ported but with stock motor home valves and on my sedan with much larger intakes cut down to 30 degrees and the 1.81 exhausts both are 9:1 motors with under .035 quench (D Dished 6 pack pistons)
                    no use you running a bigger cam on 015
                    it's the combination
                    as Iq52 says try it since you already own it
                    single pattern cam is fine with headers especially with the larger valves- hope they are not large tube headers though
                    if you then want to post back your compression readings
                    still looking for the seat duration- got a cam number
                  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                    By continuing to use this site, you are consenting to our use of cookies.
