JackBEEQuick
Hey guys I’ve recently put on a new Holley 850 street HP and been having troubles with it puking out and dying from a hard launch. After lots of mixing and matching jets, squirters, accel pumps and pump cams there is still something not quite right and wondering what I’m missing, only thing I haven’t tried is changing the power valve. I’m at my closest combo as of now.
69 coronet , Mild 440 , .528 purple cam
3500 stall
primary and secondary Jets are 83s
40 squirter with hollow nozzle screw on primary and 37 also with hollow screw on secondary
50cc accel pumps with yellow cam
Stock 4.5 PV
With a 40 squirter on the primary
And 37 on the secondary it launches perfect at 1000 rpm….
However it still Pukes out at any higher rpm and but also from a still or rolling idle.. so strange.
Now I could just make sure to always launch for that 1000rpm but I noticed my oil is gassy so it’s just too rich and am I’m tryin to figure out how to combat that and also keep it rich enough to launch hard
Any thoughts on which route to try next?
Less aggressive pump cam? I believe the blue is next one down from the yellow.
Increase Timing ?
Jet it down?
Go back to 35cc accelerator pumps (since we figured it was the pump cam?) maybe the 35cc will work but cut the fuel usage down
Grabbing for straws here I know
TIA
3500 stall
Stock 4.5 PV
Increase Timing ?
Jet it down?
TIA
