BSB67
Agreed. Kinda seems unlikely, and obvious. But you cannot assume the knowledge level of posters. And he is missing something, or failing to share a pertinent detail. There are different bases, base gaskets, and we don’t know if a spacer is being used, or a PVC.the only issue is why did he have a vacuum leak with 2 carbs he owned but didnt have the same vac leak with the borrowed carb? if it was a massive vac leak that was unrelated to the carb, it would still be there with the borrowed carb. unless he has an open port on the carb base that was blocked off on his borrowed carb.
check all holes plugged on the carb base.
I think we’re all grabbing at straws for the information provided.
