Hughes converter question
Engine, Trans & Driveline
  1. MO.RR
    MO.RR Active Member
    31
    19
    Jan 6, 2019
    Missouri
    Local Time:
    7:51 AM
  2. VANDAN
    VANDAN FBBO Gold Member FBBO Gold Member
    1,077
    1529
    May 27, 2011
    Western NY
    Local Time:
    8:51 AM
    I'm NO expert on converters, but I am in process of choosing one for my build, which seems very similar to yours. I'm working with my transmission builder, and He likes the Hughes products. You can call them directly, and have them build one specifically for your car, as You can give them the details of it. I'm just waiting for a few specs on mine, to get it done...
  3. Napoleon1991
    Napoleon1991 Well-Known Member
    61
    42
    Sep 4, 2016
    illinois
    Local Time:
    7:51 AM
    FWIW, I bought that same convertor. I followed the directions and pre-filled it and seated it correctly, and it still only lasted 100 miles. Ended up using a precision industries convertor and havent had any issues since.
    • Thanks! Thanks! x 1
    • Lefty71
      Lefty71 FBBO Gold Member FBBO Gold Member
      1,511
      1637
      Mar 8, 2018
      Ohio
      Local Time:
      8:51 AM
      This is a good question!!
      I always thought you only needed the flexplate, which is an awesome SFI one to boot, then the converter could be neutral balance. Anyone sure if I'm right or wrong??
      • Agree Agree x 1
      • 33 IMP
        33 IMP FBBO Gold Member FBBO Gold Member
        3,227
        4046
        Dec 21, 2017
        taxifornia,soon 2b Arizona.
        Local Time:
        5:51 AM
        If you have a cast crank big block, it is externally balanced, by a weighted converter, and a weighted balancer. With the b&m plate you can use a neutral converter, but you still need the weighted balancer.
        My question is.... what about the steel crank motors that use the heavy ("six pack") rods. I think there was an external balance on those too, but i dont know if it was on the balancer, the converter or both. Or even if it was the same imbalance as the cast crank motors?
      • Dipstick
        Dipstick Well-Known Member
        644
        611
        Oct 26, 2018
        Out West
        Local Time:
        5:51 AM
        Mass balanced to run smooth, not externally balanced.
      • Curiousyellow71
        Curiousyellow71 Well-Known Member
        410
        275
        Jun 18, 2019
        Nebraska
        Local Time:
        7:51 AM
        I think the converter part number listed is for internally balanced so the external balancing flex plate should work.
        I think the unusual 6 pack rods with a cast crank runs a different balancer then ly rods/cast crank and the converter is balanced the same. I assumed the convertors were the same anyway. I believe that was how the 70 6 pack was done...they made up for the rotating mass on the 6 pack damper and it was internally balanced.
        • Agree Agree x 1
        • Lefty71
          1,511
          1637
          Mar 8, 2018
          Ohio
          Local Time:
          8:51 AM
          Six pack damper was like a fat thin damper (all concentric). No big offset weight like the cast crank damper, Which you would expect.
        • MO.RR
          MO.RR Active Member
          31
          19
          Jan 6, 2019
          Missouri
          Local Time:
          7:51 AM
          that’s no bueno.
        • wyrmrider
          wyrmrider Well-Known Member
          2,330
          903
          Aug 26, 2014
          los angeles
          Local Time:
          5:51 AM
          what's a balancer
          posts 5 & 7
        • Curiousyellow71
          410
          275
          Jun 18, 2019
          Nebraska
          Local Time:
          7:51 AM
          Damper...harmonic "balancer"
          But your right just saying "balancer"....probably not the best description.Lol.
          But...I am guilty. :)
        • 33 IMP
          3,227
          4046
          Dec 21, 2017
          Local Time:
          5:51 AM
          Its that big heavy thing on the end of the crankshaft that balances an externally balanced crankshaft. And where's your question mark?:rofl:
        • wyrmrider
          2,330
          903
          Aug 26, 2014
          los angeles
          Local Time:
          5:51 AM
          Which end of the crankshaft
          are you referring to the weights on the converter
          add a question mark if you think it could possibly help you
        • Curiousyellow71
          410
          275
          Jun 18, 2019
          Nebraska
          Local Time:
          7:51 AM
          It seems like someone needs to do a sticky thread on converter weights engine combos... It would sure help prevent some mistakes.
        • Lefty71
          1,511
          1637
          Mar 8, 2018
          Ohio
          Local Time:
          8:51 AM
          From what ive read, no converter weights are gonna be requiered if he runs that B&M external balance flex-plate. This is what my thinking was asll along.
        • wyrmrider
          2,330
          903
          Aug 26, 2014
          los angeles
          Local Time:
          5:51 AM
          Right Lefty
          but which B@M
          6 pack is different than cast crank or 400
          not something you want to just pick up at a swapmeet unless you really know
        1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
          By continuing to use this site, you are consenting to our use of cookies.
