Neal Zimmerman
Here's something I cant seem to find any info on,
On our ignition switches we have a largeish Blue and brown wire. These are start1 and start2, or START and RUN. Brown wire is for start (key far to the right0 and blue is for run (key first click to right). These two wires have to do with the ballast resistor.
I was messing around and put the key to run position and put my test light on the blue wire and it lit up. Seems right. Then I decided to test the brown wire. Cranked key all the way to the right, and brown wire lit up. Seems right.
But then I put key back to run position and checked the blue wire, still good. But then I put test light to the brown wire ( key still in run position) and it also lit up, but at about half the brightness of the blue wire. Is that correct? I thought it would be a no light up reaction. But apparently some current is still travelling thru
there. ?
Is this normal or is my switch bad? And if its good can somebody explain this.
thanks
Neal
there. ?
thanks
Neal
