Sneaaky
New Member
Hi, I have a few questions about the instrument cluster.
I've already repaired the EL backlight and needles. After reassembling i wanted to test it. I assumed each gauge would be grounded through the metal housing, but that doesn't seem to be the case. Do I need to connect the wiring harness to test the cluster on the bench, or am I missing something?
My second question is about the gauge needles. I've already painted them, but they don't look the way I wanted. What kind of paint shuld I use for them? I've tried a few different ones that i had laying around, but none of them were good enough.
My third question is about calibrating and testing the gauges themselves. I know they all work, but I'm not sure if they're reading accurately. I'd really appreciate any information on how I can properly test and calibrate them.
One last question: is it possible to install the entire fully assembled dashboard into the car as one unit, or does everything need to be installed piece by piece?
e?
