It's a matter of Balance! 1968 GTX
zyzzyx
5:57 AM
Lisle, Illinois
So, I finally broke down and changed my Left Front lugs to RH thread and was wondering if the drums have
to be clocked a certain way to the hub to be balanced???? I removed the drums off of the hubs years ago
to blast and paint them and while they are still with their original hubs, I neglected to match mark them for
position on the hub. Does anyone know if when you cut the drums, do you put the drum itself on the machine
and cut it or do you put the hub & drum assembly on the machine and cut it? If I screwed up, I'll have to
make up an arbor and static balance the hub/drum assembly and keep moving the drums around until I get
it right! Thanks for the sanity check!
