It's always something
jusglazin
9:26 PM
Charlotte, nc
Just bought a new transmission for my 66 belvedere. Go to swap it in and the damn mount location is different. Didnt bother to check that B vs B/E tailshafts are different. Get ready to bolt it up and the mounting pad is almost a foot to far forward.
Geez time to get out the welder...
Demonic
9:26 PM
Maryland
If the output shaft length is the same, just swap output housings. It's easy.
Richard Cranium
8:26 PM
Maskachusetts
Geez time to get out the welder... View attachment 1290228 View attachment 1290229
Looks more like 2 1/2" to 3" to me. I wonder if an automatic crossmember will do the trick.
moparedtn
Ed on the Ridge
9:26 PM
On the Ridge, TN
What I was thinking also.
This almost new trans crossmember I bought from Brewer's allows installation of '70-up transmissions into older
b-bodies (like my '68 GTX).
I swapped 4 speeds shortly after I used this one, went from a 23 to an 18 spline from '68 and used the
old crossmember, so this one is shiny and gathering dust on the shelf now.
Do you need it @jusglazin ??
moparmarks
I'm just a guy with a screwdriver.
7:26 PM
Western Colorado
I have a couple 66-69 tail housings if you go that route.
Superbeemike
6:26 PM
Sparks, Nevada
I think my setup is the same as yours. I was able to use my automatic crossmember during my 4 speed swap by installing it flipped the opposite way.
65Bel
8:26 PM
central Illinois
Or, "with the help of an a-dapter kit" as Johnny Cash once said . . . fabrication time?
R413
6:26 PM
NW USA
You have the wrong crossmember. Get the right one and it bolts together. Post 3 & 4 show the right one.
69Bee
6:26 PM
Whetstone, AZ
If the difference in your pic is what you are calling a foot (12"), you need a new tape measure too... :poke:
jusglazin
9:26 PM
Charlotte, nc
Ha ha, you guys are so correct. Thats why I come here! I forgot I cut the last one which was for a Auto to make it work. Need to look in my scrap parts to see if I still have that piece to weld back on. Otherwise I hit one of you up for the correct crossmember.
moparmarks
7:26 PM
Western Colorado
On a 4 speed it’s not easy, have to take the trans apart.
Yep you have to pull the main shaft out and then reach in there and get that big ass C clip out there to remove the tail housing
