Just a quick question
Jbland
12:16 PM
Texas
Hello, I have a 68 charger with a crate 5.9 and mild comp cam in it. I am running a 600cfm edelbrock carb. I recently got engine to start and hold idle after working out some ignition issues with your help. My question now is I have drops of water from exhaust even after engine is warmed up and what seems like an excessive amount of whitish gray smoke when I bump the throttle it plumes out pretty good. Is this normal? The outside temp is around 35 degrees. It doesn't smell sweet like coolant but more of an exhaust/fuel odor. Just don't want to keep running it and damage something if I have an issue. Thanks in advance!
If you have not driven this any where that is just condensate that you will get until your whole exhaust system is above 130f not just the motor
