So done with the red '70 and starting on the '70 on the top?
The red 70 has always been done. Still unrestored and I have had since I was a teenager. Bought it as is over 32 years ago.So done with the red '70 and starting on the '70 on the top?
My height is 9’8”. I can’t get another car under it, which is fine with me.So for those of you with lifts...what's your ceiling (joist) height from the floor? Considering one...but not sure if I have the room to put a car on a car, with a lift between....
I’ll take some measurements for you this weekend.well I finally measured mine...9'4". Dammit. I'll have to measure car heights - my (91) Daytona is pretty short/low, it *might* fit under the '70 Charger...anyone able to measure the section height of your lift platform for me? And maybe the distance between wheel troughs? Thinking if they're "close" but spread far enough, I can sorta tuck the roof in between the troughs if it won't fit totally under them...
That is probably not tall enough. The runner thickness of the hoist is 6". I have 3-4" from the top car to the ceiling and 6-7" between the top of the bottom car and the bottom of the hoist. Don't forget you need a little extra lifting clearance, another 1-2" to release the safety catches before you can lower it also.well I finally measured mine...9'4". Dammit. I'll have to measure car heights - my (91) Daytona is pretty short/low, it *might* fit under the '70 Charger...anyone able to measure the section height of your lift platform for me? And maybe the distance between wheel troughs? Thinking if they're "close" but spread far enough, I can sorta tuck the roof in between the troughs if it won't fit totally under them...
triplegreen500:I’ll take some measurements for you this weekend.
You won’t be able to tuck the roof between the troughs using the Bendpak lift I have. The bars across the front and rear will be the max height allowed for the car.
You can see what I mean in the pic in the Manual. I have the HD-7W
https://www.bendpak.com/HD-7-Four-Post-Lift-Manual-5900041-BendPak.pdf
