K-frame conversion
moparman73
5:07 PM
Upstate South Carolina
I have seen over on the FABO site how to modify your small block k-frame to duplicate the Direct Connection big block k-frames---so, my question is, will it work with a 73-74 B-body? Anybody tried it? I seems really easy and straightforward with the A-body parts.
Easier to use the Schumacher mounts. (It's what I did). Or you could locate a B-motor K. There are still quite a few out there.
I know on the earlier B-bodies there is only one K-frame (except Hemi) The only difference is the mount, 73-74 not 100% sure but Schumacher makes good stuff and they already did all the work for you...
73-74 K frames...buy the Schumacher mounts, or get a Cordoba (or equivalent) K-frame.
