True, but you can install a 71-72 K member in a 73-74 car can't you? You're changing the suspension, but it will install won't it? The torsion bars will not.
With a bunch of fabrication and welding I guess you could. 73-4 frame is much larger and the bolt spacing to the frames is longer. Also the 73-4 bolts are smaller diameter. No where is it a bolt in thing.
