We all know that often times, a project includes a few obstacles along the way. A few
hiccups are to be expected and I do expect them.
The 20-9 Holley bracket looked like it would be a direct fit.
It was not.
The base of the bracket fit the carburetor but the shape just didn’t fit and clear the throttle lever or accelerator pump so…. I cut, shaped, tack welded and test fitted….
Keep in mind, the bracket is just tacked together and not finished…
The solenoid fits and is aimed correctly as far as I can tell.
I mocked up an extension on the throttle shaft so the solenoid would have a place to press against. Again, this is mock up stage.
The air cleaner does not sit down all the way.
The body of the solenoid sticks up too high and the underside of the base plate hits it. The bracket clears, the throttle shaft clears but the bulbous solenoid sticks up too high. I can't lower it down from it's current spot because the accelerator pump is about 3/16" below it.
This means I’d need to move the solenoid out further and down lower to clear. Yeah, I can do that.
I hooked up wires to test the solenoid just to see it open and push the throttle open like it would in normal operation. I grounded it and put power to it but got nothing. I keep trying…
nothing. It turns out this solenoid isn’t strong enough to overcome the throttle return springs. Huh?? Yeah. The solenoid works but just isn’t strong enough. It isn’t like I have a real firm pedal either. Maybe the solenoid is defective?
There is more though. The way I made the bracket, it blocks the idle mixture screw.
I could drill a hole in the bracket for access but for now I’m stepping back from this. I only bought this Holley solenoid because Holley also had a bracket to make it work. The dang thing was $140 when other generic solenoids were much cheaper.
Maybe I’ll try manifold vacuum after all…..
