I inspected the driver side rocker arms. Looked under the valve cover and no witness marks can be found. After checking each push rod for spin/play, I found the #3 cylinder exhaust rocker/pushrod to have some up/down play. All other assemblies seemed normal. Valves open - no spin, others tight to moderate friction to spin.
I adjusted the rocker about 1/4 turn to get the play out and have a moderate amount of friction while spinning the push rod.
Before doing any of that, I pushed down firmly on each arm to see if I were able to compress any of the lifters and I could not.
we shall see in an hour when I start her up if that quiets things down. I'm optimistic that it will.
I also reached out to the builder to schedule a visit........
