Oil stabilizerAny body have a thought on putting some Lucas in my 66 charger 383?
I'm an amsoil dealer, wonder if they have anything with the zinc additive in it? I never sell any of it, lol. I end up using it.I use it.
We sell Lucas where I work, they have a high zinc oil.I'm an amsoil dealer, wonder if they have anything with the zinc additive in it? I never sell any of it, lol. I end up using it.
If it was a fresh engine it could be moly lube or this assembly grease that some guys use on bearings, looks like white lithium grease if you ask me. But whatever it is, good you got it out of there.As long as you have conventional oil in it.
Add it warm and run it right away.
Always drain the oil warm/hot as well.
Some caution here:
When I took the pan off my Plymouth that I bought (a fairly new rebuild) I think they used STP or some type of additive.
The bottom 1/4 - 3/8" of an inch had a layer of almost grease from stabilizer or something that dropped out of suspension.
If it covered/blocked the oil pickup it would have been new engine time...
No there was way too much of it.If it was a fresh engine it could be moly lube or this assembly grease that some guys use on bearings, looks like white lithium grease if you ask me. But whatever it is, good you got it out of there.
