- 11:56 AM
- Apr 13, 2012
- Granite Bay CA
We have all heard of "Paint Jail".....the term used to describe that condition where your car sits waiting for the bodywork and paint to be completed.
Equally frustrating is waiting on a machinist.
In the first week of June, I brought in a 440 block, crank, rods and pistons, heads, and cam bearings. I needed the block bored and honed and the crank installed to determine piston height at TDC. Deck the block, and hot tank it..... change valve springs and light surface to the heads.
It has been two months. Last week the man said that THIS week he would have it done.
I took this rebuild as an opportunity to fix a few other things and to upgrade the brakes. Even with a few other projects going on here, I've exhausted all the things that I can do on this car until I get the engine back. To make it worse, the new pistons are 100 grams heavier and will require a balance job.....that this machinist cannot do.
This guy does great work and is reasonably priced so it seems that I got 2 out of three:
Fast
Cheap
Good.
Fast
Cheap
Good.
