Magnesium anode to stop the rust
General Mopar Tech Discussions
  1. 440 Charger
    440 Charger FBBO Gold Member FBBO Gold Member
    565
    273
    Aug 1, 2020
    naples Fl
    Local Time:
    11:59 PM
    Thinking about using some old boat tec for freshwater. Bolting it to the frame and let the rain begin.
  2. Slap Stick
    Slap Stick Well-Known Member
    5,606
    6094
    Jan 15, 2017
    Missouri
    Local Time:
    10:59 PM
    Hmm...that should work. I don't see why it won't.
  3. 440 Charger
    565
    273
    Aug 1, 2020
    naples Fl
    Local Time:
    11:59 PM
    To see outside of the box is awsome. I am going to do it let you know how well it works.
  4. funknut
    funknut Well-Known Member
    1,335
    1583
    Jul 29, 2015
    Cincinnati, OH
    Local Time:
    10:59 PM
    I think you might have some success if you put the anode on or very near areas you want to protect, but no way a chunk of Mg up front would protect the rear from corrosion. The reason it works better on boats is they are all in the same electrolytic bath (seawater).
    Most of these types of rust protection schemes have been proven to be snake oil, you might have some small benefit but I wouldn’t count on much.
    • Agree Agree x 1
    • 440 Charger
      565
      273
      Aug 1, 2020
      naples Fl
      Local Time:
      11:59 PM
      Was thinking at least 6 points
    • 440 Charger
      565
      273
      Aug 1, 2020
      naples Fl
      Local Time:
      11:59 PM
      Cant see the hurt at all
    • hoover
      hoover FBBO Gold Member FBBO Gold Member
      111
      99
      Aug 3, 2017
      taylors falls mn
      Local Time:
      10:59 PM
      I always thought those were zinc.
    • Slap Stick
      5,606
      6094
      Jan 15, 2017
      Missouri
      Local Time:
      10:59 PM
      Zinc is correct.
      And they are used on fresh water boats, also.
    • Dajkzo
      Dajkzo FBBO Gold Member FBBO Gold Member
      373
      933
      Jan 19, 2019
      southern Maine
      Local Time:
      11:59 PM
      I'm a long time boat owner. Funknut is correct. It's a sacrificial anode, but only works in water hence the term galvanic protection. Really good/clean ground on the body will help.
    • Daves69
      Daves69 Well-Known Member
      1,883
      1657
      Jan 24, 2014
      ChiWest
      Local Time:
      10:59 PM
    • dadsbee
      dadsbee FBBO Gold Member FBBO Gold Member
      9,230
      21880
      Jan 29, 2018
      Midland Ontario, Canada
      Local Time:
      11:59 PM
      Just don't back too far down the boat ramp and you should be good!
    • YY1
      YY1 Well-Known Member
      17,344
      9411
      Jun 26, 2010
      FL
      Local Time:
      11:59 PM
      Would it work in the rain?
      How would you know it's working- by material missing from the anode? Weight maybe?
    • 440 Charger
      565
      273
      Aug 1, 2020
      naples Fl
      Local Time:
      11:59 PM
      Yes you will see the anode corroding.
    • 440 Charger
      565
      273
      Aug 1, 2020
      naples Fl
      Local Time:
      11:59 PM
    • 440 Charger
      565
      273
      Aug 1, 2020
      naples Fl
      Local Time:
      11:59 PM
      Read the link zinc are best for salt water magnesium is best for fresh I will be calling a manufacturer to see what would help best if any. The reason I thought of this is if you check into home water heaters the difference from a 6 year warranty to a 12 is nothing but they put a pencil anode in one of the tank plugs. Lets hope it works.
    • 440 Charger
      565
      273
      Aug 1, 2020
      naples Fl
      Local Time:
      11:59 PM
      Lol true that.
    • 440 Charger
      565
      273
      Aug 1, 2020
      naples Fl
      Local Time:
      11:59 PM
      I am hoping so Dave69 posted a link above check it out
    • BB BELLA
      BB BELLA Well-Known Member
      472
      484
      Jul 27, 2018
      Severn Bridge
      Local Time:
      11:59 PM
      the boats need it because of the disimilar metals, stainless and aluminium. I don't think the anode will do much for a car unless it has an aluminium body!
      • Agree Agree x 1
      • Cranky
        Cranky Banned Staff Member FBBO Gold Member
        22,950
        20971
        Dec 4, 2009
        Pasa-getdown-dena Texas
        Local Time:
        10:59 PM
        How bout aluminum radiators.....?
      • dadsbee
        9,230
        21880
        Jan 29, 2018
        Local Time:
        11:59 PM
        Yep, different metals and voltage leakage that creates the plating process. The Zinc is the sacrificial. Why I said as long as he doesn't back too far down the ramp he should be good... without it!
        Unless you put it in the radiator filler neck an anode on the frame ain't gonna do squat.
      1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
        By continuing to use this site, you are consenting to our use of cookies.
