Manual disc brake master cylinder
Beekeeper
It’s a disease without a cure!
8:08 AM
Rogersville,TN.
which 4 bolt master cylinder do I need for manual disc brakes on a 69'
Coronet?
What bore size are most guys using? I see a 1" and 1.125". Mine originally had drums and I am changing to
mopar single piston calipers.
I think the manual cars used a 15/16" bore.
Kern dog,
Thanks for the info on the master cylinder
jegs carries a 15/16" bore master cylinder from right stuff for 65 dollars. Works well.
DBMC10 is what I've been using, no problems at all. Right stuff detailing. Summit and jegs carry it
I'm planning to use the 73' up A body single piston calipers. Anyone used the 73' up disc/drum master cylinder with the factory manual push rod? Was wanting to 1" or smaller bore for less pedal effort
