Max wedge hood
300
2:57 AM
Canada
Hi, Anyone have a Max Wedge dual 4 barrels without a hood scoop? Any clearence issure with a flat hood?
Talking 64-65 Clones or real, I'm doing one, do know if I have to cut hood for the air cleaners
Thank You
I had a 63 dodge max wedge, you just have to cut the center bracing out to clear air cleaners. No hole in hood is necessary unless you install the scoop.
I guess I should clarify, would I have to cut bracing out, To clear the offset air cleaners, Have a 65 Satellite, 440 Max Wedge set up
Thanks
Well the factory cut out the hood bracing for the air cleaners to clear. So I would say yes you need to cut the hood bracing. Ron
64 Fury, stock carbs and stock air cleaners, cut the bracing out and it all fits.
273.jpg This is my '62 sedan. The bracing is not cut an there is clearance. I do have a torque strap to limit engine movement. It's close but there is room. At least there is on my car.
