Mechanical fuel pumps
moparjohnny
1:02 PM
ga
Who sells good fuel pumps i want mechanical hopefully usa made if possible. Thanks
Carter. Forget HiPo. Just get the right application. Summit, ebay, Amazon.
i will be using a holley 750 or a holley 600 for street use, what fuel lines are you using pump to carb,600 has one line to carb how would you plumb that all metal lines are rubber and metal? 750 has dual feed what would you use for that? thanks
