Done... Thanks.Then get one !!
Big block. Not sure of the year though. The estate I bought the car from didn't really know too much about what was done.Something is hitting on the block IMHO. Some mini starters have an electrical adaptor mounted that can interfere. It can be removed. Is this going on a big block or small block?
Precisely , it's a combo pack of grinding the starter gear boss and the block casting as shown.Didn't see it mentioned, but some mini starters are cast with a protrusion near the gear area that makes them not seat fully.
If you locate that and grind it down/off it might work.
The one I had however, would not even seat correctly with that casting as it was.
I could get one mounting point, but not both.
I wasn't screwing around though, that starter was supposed to fit.It's time to stop screwing around and get the RIGHT starter:
Chrysler p/n 56027702AC (Denso 228000-7421) 99-03 Dodge Dakota/Ram/Ram van.
The application is supposed to be for my 67 Charger with a 383. It bolted up fine, the wire was a few inches shorter, so I'm going to have to make a new cable for it now. It sounded like it was spinning and just not hitting the flywheel. I ordered a shield for the mini starter as there was a tiny gap at the bottom and I'm going to add another stud. I found I should be able to move the starter forward to clear both studs. That will make it much easier to install the mini starter.So what is the application your starter is for? I have put them in all of my cars (3) plus a number of friends cars (4) and they have always worked. I use one from a 93-95 Dakota or 1500 with a 360. Typically I remove the top electrical connection adapter as well.
I understand what you are putting the starter into, I was asking what the starter is supposed to be for (i.e. mini starters were not around in 67 obviously). There are a number of different "mini" starters out there that were all designed for different applications, some fit better than other (there are some that will not fit a muscle car very well or at all).I wasn't screwing around though, that starter was supposed to fit.
The application is supposed to be for my 67 Charger with a 383. It bolted up fine, the wire was a few inches shorter, so I'm going to have to make a new cable for it now. It sounded like it was spinning and just not hitting the flywheel. I ordered a shield for the mini starter as there was a tiny gap at the bottom and I'm going to add another stud. I found I should be able to move the starter forward to clear both studs. That will make it much easier to install the mini starter.![]()
I don't know really what it supposed to be for. I bought it from AutoZone's website and that's what it came up with. I bought if from them because it had a lifetime warranty and its easy to return if necessary. I guess I should have broken out the tape measure like I did with the one that came form Rock Auto. I just did a visual check with the old starter and the new one and they looked close. After measuring the two, the nose is the same length and from the top of the gear to the tip of the nose is the same on both.I understand what you are putting the starter into, I was asking what the starter is supposed to be for (i.e. mini starters were not around in 67 obviously). There are a number of different "mini" starters out there that were all designed for different applications, some fit better than other (there are some that will not fit a muscle car very well or at all).
Thats probably fine but I do know that there were differences in mini starters from various years. I found that 93-95 Dakota/Ram 360 variants work well.I don't know really what it supposed to be for. I bought it from AutoZone's website and that's what it came up with. I bought if from them because it had a lifetime warranty and its easy to return if necessary. I guess I should have broken out the tape measure like I did with the one that came form Rock Auto. I just did a visual check with the old starter and the new one and they looked close. After measuring the two, the nose is the same length and from the top of the gear to the tip of the nose is the same on both.
Did you have to trim the shield when you put it in? I had to trim the hell out of it. After putting it in, I found a larger gap on the top is the starter this time. I’m gonna pull it out and put it in without the shield and see what happens. Looks like I might have to get the starter that came with the car rebuilt. My mini starter idea was a bust.Done... Thanks.
AC Delco for 1995 (photos 1-4) and 1999 (photos 5-8) Dakota with 360.
You have big block thiss for in?
It probably is me; I guess I should have never tried to put one of these mini starters in. I wanted to put a new starter instead of another rebuild that might fail in a few months like the one that was in the car.I have never heard of anyone having this much trouble with a starter !! I'm beginning to think the problem isn't the starter or the engine !!!
Totally agree !!not buying the notion there are a bunch of different snouts on a mini to be dealt with.
Looks the teeth aren’t going out far enough. Take a look at both starters. I put a mark where the teeth are extended. When the mini starter extends its teeth, they seem to not engage the flex plate.AC Delco for 1995 (photos 1-4) and 1999 (photos 5-8) Dakota with 360.
I'm going to try this one next.These are what I went with. The terminal cover looks simpler to work with the relocation kit.
https://www.amazon.com/gp/aw/d/B007QBTUKW NEW AC Delco Starter for 95 Dakota with 360
https://www.ebay.com/itm/303833501832 Terminal Relocation Kit
https://www.manciniracing.com/mastsh.html Starter Shield
This is the one AC Delco shows for the 99 Dakota. They look just about the same except for the terminal cover. I’m assuming the same two bolt are found under the black cover. The kit above makes this irrelevant.
https://www.amazon.com/ACDelco-337-1155-Professional-Starter/dp/B00S0DEFAA
