FOR SALE mopar 426 hemi crossram ray barton intake superstock
stage3
7:28 PM
california
Feedback: +5 / =0 / -0
Want to haul ash this intake is for you, ""show or go"", i ended up with 2 only want 1.highly modified ray barton Superstock class crossram intake ,
custom high end crossram from barton,, this intake represents the Peak of stock style crossram's before they went to sheetmetal intakes. Big HP can be made.
the area along the intake ports/plenum has been clearanced for valve covers. Again very nice work with a milling machine No grinder. the bolt holes are not elongated either as so many are because of imperfect intake to head alighnment.....
4995.00/offer shipped anywhere in the lower 48 Only.
Is that just a big plenum, no tubes??
the plenum has been raised to offset the air dams directing air to the runners, has the interconnect channel , both my intakes was ported/polished by barton and this 1 is much nicer than the 1 im running.
the units that r motor specific Usually have welded up runners Otherwise you just use the correct thickness gaskets. mine installed with .060 with perfect intake to head alignment...elongated bolt holes r usually the tell and these are Not that way.
here's a couple of pic showing this intake's brother installed, your reference is the raised plenum parting line and air dam bolts on the front...
Bump for a very cool intake. I would love to swap out the A&A repop intake on my 68 SS barracuda clone race car for this piece. I would probably drop a couple tenths with it.
I hope this part finds a home on a car that is raced hard.
Yep a stock MP crossram flows 100CFM more than a stocker , looking at barton's port and polish work on this unit along with the directed air dams it should be a monster..
just got my hemi running with my other barton intake, just testing and tuning it You can feel the power. instant throttle response.
5300.00 shipped(continental USA) with barton prepared 770cfm 4235-36 holleys. all he told me that he would disclose is that they have been upgraded with bras floats which i did confirm....
I have one of these same RBRE cross ram Hemi intakes as well. The entire inside of mine is coated with some sort of light green gravy epoxy throughout and is all very smooth. Someone spent alot of time applying this coating.
Yep the craftsmanship on it is very good, the polish on the runners is the smoothest i have seen, much more time spent on this 1 compared to the unit im running..
been too busy to clean it up yet,,,,some steel wool will make it look like New.
updated pic's. had a chance today clean it up some. gasket is still in place, the white stuff u see on it is Grease barton used to seal the directional air plates. its a work of hi performance art. wash it and install. 3500.00, also have the holley 4235-36 barton prepped carbs for xtra $$$...
