Najib
I have been troubled once again. I am getting ready to get all my parts around since I just got my 440 back from the machine shop. I got 906 heads that are ported. I am going to be running a tunnel ram setup with 2 efi carbs from FiTech. I am still deciding if I want to actually run a tunnel ram or if I should just run a hi rise dual carb intake which In my opinon might work better. I am also trying to decide if I should use my stock crank or just get a eagle crank. I have heard that somtimes the eagle crank does crack. Not sure cause I have never actually used eagle. I have also heard that 440 source was decent but trying to save some money while still doing the job right. I am wanting a hydraulic roller cam kit that comes with the cam, lifters. valve locks, etc. I am looking a cam with a nasty thump thats around 4-500 degree lobe lift. I am also looking for a mechanical advance distributor I got gears laying around the shop that I would use for the distributor depending on the cam. Also running arp bolts and studs for the whole motor. I havent got a stall converter due to me not finding a cam and what the cam company calls for torque converter wise. I havent decided what rear end gear ratio to use. I just need suggestions on parts that work well together well and what has worked for you guys the best.
If You havent seen any of my other embarrassing post of mine I am running a 73 charger se that im restoring at the moment. Disc break conversion on the rear and different front brake system in the front. I am getting ready to take the body off to blast it and see what needs repaired. I got fairly lucky as there is really only front fender rust that I am seeing so far, and some floor pan rust.
https://www.ebay.com/itm/263541278124 <--- Heres the Distributor I would like to use.
