Don’t have the gun to measure the air coming out but it feels cool. Small line does not feel warm at all, big line not sweatingWhats the outlet air like coming out of the ducts?? 15-20 degrees colder than the air in the house?? How about the refrigerant lines? Small one warm but not hot? Big one should be sweating just before where it goes in the outside unit, but no frost or icing. Everything running inside and out?
Can’t get ahold of any of my HVAC guys, go figureNo if its not sweating you are probably low. Back it the day we used ti charge by sweat back. Add refrigerant until you start seeing the suction line sweating...its close and will get you cooling...
Yes brazed that’s what I meant. And no I did not know that that’s why I’m consulting with you guys. Looks like I’m gonna have to buy my friend a case of beer and have him come do it for me. Thanks for all your help guys I appreciate it.Never did catch the details... Isnt this a new outside unit, meaning using R410A??? If so, it runs at a high pressure and all joints must be brazed, never soldered. Also, you do know YOU MUST PULL THE SYSTEM DOWN AND OPEN THE LINES TO ATHMOSPHERE before any attempt at a repair right?? Just making sure you stay safe. HTH, Lefty71
Update: found the leak, pumped everything down to the compressor, went over my joints added 2lbs of Freon and I’m back up and running. Thanks for the help guys.
Right on! That’s COOL!
