dsd1967
I just attempted installing a one piece kickdown in a 67 D100 pickup and it hits the firewall. Now I'm attempting to piece together a 3 piece setup from my piles of parts and need some help with some dimensions.
This is for a 400 with a 727
Lower rod - what is the dimension from center to center on the pivot ends
Lower pivot - what is the dimension from the pivot centerline to each rod hole centerline and what is the dimension between rod hole centerlines
Mid rod - what is the dimension from center to center on the pivots
Upper pivot - what is the dimension from the pivot centerline to each rod hole centerline and what is the dimension between rod hole centerlines
I think I have the right lower rod, but I have two lower pivots with slightly different dimensions. On the mid rod, I have a solid rod and one with an adjustable upper pivot....but suspect they may be small block.
If I can identify the pivots and the rod lengths...I can make the rods I need. Any help would be appreciated.
Dave
Dave
