Greg Berlin
New Member
I purchased a 1967 dodge coronet sedan with a 440 big block swap and 727 transmission about a year ago and haven’t had a ton of time to drive it, but I noticed it had a leak that looked like tranny fluid so I took to a shop and they replaced the torque converter seal and said that was leaking, then after they finished the work, he told me it was stuck in high gear and it wouldn’t go very well in reverse either and he claimed that the tranny is shot and if I sourced a new one, he’d put it in. I’ve noticed that I didn’t think the car had the power that it should and he said it’s because I’ve been taking off from third gear everywhere. I’m a little skeptical of that claim, but he doesn’t rebuild transmissions at his shop. I was going to take it to a recommended local transmission shop and see what they think but I was wondering a few things. A) does this seem like a common issue and does that mean the tranny is toast? B) are there any 727 transmission suppliers that people recommend if replacement is necessary? C) any recommendations on features I should be looking for in a replacement transmission that would make it more durable and better shifting and able to give some room to grow should I start adding to the 440? Right now the 440 has worked over 906 heads and a mopar cam with an Edelbrock carb and aluminum install and exhaust, but I’d love to eventually purchase a top end kit for it with heads and whole works down the road D) I also priced up a complete 4 speed replacement kit from brewers as well thinking this might be the best time to do a swap. I’m pretty mechanically inclined but I’ve never done a transmission swap before so if I went that route, I figured a complete kit would be worth the investment to make sure I have EVERYTHING I’d need to do a swap, but they are $$$$
So any help or advice or feedback people could give would be awesome! Thanks!
