67Satty
I switched from iron heads to aluminum heads. I hooked everything back up exactly the way it was before: negative battery cable attached to front of driver's side head, braided ground strap going from back of passenger side head to firewall. Trying to crank it over ended up smoking the 12 gauge wire that's crimped to the negative battery cable pigtail that goes to the inner fender.
So the only thing that changed it switching from iron to aluminum heads. Could that have caused the grounding problem? Or something else like bad connection between the cable terminal and the negative post of the battery? Or maybe the crimp connection between the negative cable pigtail and the 12 gauge wire going to my inner fender was crappy? Any ideas? Thanks!
