Paul_G
- 8:47 AM
- Dec 24, 2013
- Surprise, Arizona
I put a new clutch in the 73. It has a stock built 440. The bearing retainer was leaking badly, while down to fix that I put a new clutch in as well. The old disc was oiled up so even tho only 2000 miles on it, it had to go.
I got a Zoom MU 1858-1a from Summit. Stock replacement Borg and Beck style.
The problem; I adjusted the clutch linkage to have the throw out bearing just clear the pressure plate fingers and turn freely. Went inside to test the clutch, engine off, and the pedal goes to the floor and stays there, had to pull it up and it snaps back in to full up position. What the hell? The over center spring is still on it, Borg and Beck style. I adjust the linkage a little tighter and put a stronger clutch fork return spring on it. Pedal still stays on the floor. So I remove the over center spring. Now the pedal comes back up off the floor but the clutch has no feel to it. Started the engine, clutch out and it sounds normal. Depressed the clutch pedal and when at the floor it starts screeching a metal on metal screech. What the hell#2.
I dropped the trans and pulled the clutch back off. Everything looks normal, cant really see any witness marks from the screeching. Something isn't right.
