- 8:38 AM
- Jan 1, 2013
- Mascoutah, Illinois
I bought Wedge's TCI pan and it should be here any day. I also went digging / shopping in the ole garage and pulled out the B&M street and strip trans I got 23 years ago with another 68 RT I bought back then. The trans was new-ish at the time and has just been sitting in the garage collecting dust the past 2 decades.
I dropped the trans off with a friend of a fried who rebuilds 727's and it will get freshened up prior to going in my current R/T. I read up on the specs and it will shift automatically or you can shift manually and has other perf upgrades like the 5.0 lever, 5 clutch pak, HD Band, etc. I am now more anxious than ever to get done cleaning up the engine, engine bay, rebuilding front suspension and brakes and putting it back together. I also dropped off at set of 915 heads with my machinist buddy for a clean up, changing 1.6 exh valve to 1.74, 3 angle valve job, and massaging.
Description
Street/Strip 1967-1979 361-440 cid non lock-up with 18-3/8" tailshaft
Chrysler TF-727 Street/Strip transmission
* 2.45:1 first gear ratio, 1.45:1 second gear.
* Rebuilt front pump.
* All new B&M high performance friction plates.
* New special bellville spring.
* Five clutch direct drum.
* New low roller clutch.
* B&M 5.0 servo lever.
* Four pinion front carrier.
* Fully recalibrated valve body.
Item# 111212
http://bmracing.com/?wpsc-product=st...8-38-tailshaft
Description
Item# 111212
