New trunk weatherstrip going on today, should I close the trunk after gluing and taping it down or leave the trunk open and just let the tape hold it in place?
When I did mine I used no tape at all. 3M black super weatherstrip adhesive. Did about 6 inches or so at a time and when used properly once you set it it stays.
I originally put a SofSeal strip in and couldn't get my trunk shut! I bought one from DMT
and right on their description of their weather strip it says that others are too thick and
theirs does not cause the same problem. I put DMT's on and closes with no problem!
Don't forget to install the seam at the bottom about 6" off to the right of the trunk lock
pawl! Use plenty of clothes pins!
