Non-original idler arm?
kaj750
4:01 PM
Fresno, CA
The bushing on my current idler arm is rotted so I removed it. Ordered a generic Moog k7041, from RockAuto (OEM / Interchange Numbers: 2535793, 2535886, 2835834). It is much shorter. Is this going to be a problem?
The steering box Firm Feel with a quicker ratio. I assume the idler are my pulled off was part of that kit as a whole? Or maybe it's meant to have a longer one installed with the new box? Or, did I just get the wrong part from RockAuto?
I couldn't find any established threads that addressed this exact issue. Thanks, in advance.
These are Moog part numbers for Mopar idler arms. There are quite a few. It should match. yhe original.
Doug
LISTING BY APPLICATION
The discontinued Moog pitman # K7024 is for 67-73 Imperials. Pitman # K7017 and idler # K7009 is for 63-66 Imperials.
The Moog catalog numbers idler and pitman arms for rear wheel drive cars are:
Group 1
Chrysler: 65-73 Newport/300- Dodge: 65-73 Polara, Monaco, 880 - Plymouth: 65- 73 Fury
Pitmans: K7072 Power Steering Idler: K7014
Group 2
Chrysler: 74-78 Newport, 74-75 Imperial- Dodge: 74-76 Monaco, 75-77 Royal Monaco - Plymouth: 74 Fury, 75-77 Gran Fury
Pitman: K7121 Idler: K7073
Group 3
Chrysler Newport 79-81 Dodge: 73-79 Charger, 77-78 Monaco, 79-81 St. Regis Plymouth: 73-75 Satellite/Road Runner, Fury 75-78, 80-81 Gran Fury
Pitman: 7076 P.S. Idler: 7066
Group 4
73-74 E body, 70-72 IDLER ONLY E-body, 68-72 IDLER ONLY B-body
Pitman: 7076 P.S. Idler: 7041
Group 5
Plymouth: 62-64 All, 65-67 Satellite - Dodge: 62-65 All (except 880), 65-67 Coronet
Idler: 779
Group 6
Plymouth: 68-72 A-body - Dodge: 68-72 A-Body Dodge & Plymouth: 67 A-bodies pitman only - ALL big blocks pitman not listed
Pitman: K7074 Idler: K7042
Group 7
Plymouth: 73-76 A-body - Dodge: 73-76 A-Body
Pitman: K7076 Idler: K7086
Group 8
Chrysler: 77-81 Le Baron, 81-83 Imperial - Plymouth: 76-80 F-body, 82-89 Gran Fury - Dodge: 76-80 F-Body, 77-89 Diplomat, 80-83 Mirada,
Pitman: K7101 P.S. K7100 Manual Steering Idler: K7086 (Exc Police and Taxi)
The catalog lists the part #'s by body style. I rearranged this to grouped by part #'s. This I think would be helpful to us.
Note: you can fit a 68-72 A-Body idler on a 67 A-Body and it will work.
Well beling shorter it WILL move the center link closer to the oil pan - which would certainly be a problem for me !!
