Oil pressure
Polo62
3:52 AM
Woodland ms
Can I get a true oil pressure check with a drill and shaft running to oil pump on a 440
you won't get oil up top unless you rotate the assembly while drilling, so I would say "no"
I did with mine; 75 p.s.i., with my wife spinning the engine over on the starter. Use Wix filters, not Fram.
Any engine that I’ve primed on a drill will go up to full pressure. Pressure is one thing, lube everywhere like @eldubb440 said is another.
You can verify it has pressure. Slowly rotating a few degrees at a time will ensure the cam holes line up to feed oil to both heads/rockers. Most times you will see around 70 psi. However when the engine is running in the car that psi number will drop. The actual running pressure will depend on pump volume, oil weight choice, oil temperature, and internal clearances.
Doug
I think the answer to your question is no.
The priming oil pressure will not reflect operating oil pressure, if that is your question.
Doug
Is 30psi enough to drive it that's what my gauge shows 30 to 35 with it running
30-35 is ok....... does it increase at all with RPMs....... thicker oil might give it a bump
The motor is inshop hanging on a chain hoist you can't rev it much wants to turn over maybe 2000 rpm and it didn't get over 35psi and only 30psi with drill and someone spinning motor with starter
Lucky to have 15 psi on the 440 in my Bird. Have run the **** out of it for 34 years.... zero issues.
Thanks man I just wanted to know before I put it in my charger done put a 400 in it that runs crappie bad valves or cam wanted this one right because that's lots of work to keep changing engines but the 400 has 60psi
