440rb
Hi, were running my mates RR next year with a totally new combo, I don't know all the full spec but can tell you what I know, car will be raced and run in brkts and on a lot of short trips on the street, would appreciate your thoughts.
3850lbs?...10:1cr 589ci, 4.500x4.625? Mega Block, -13's, 365's/385's?, small solid roller .620" 112ls don't know duration, could be the Indy R-1 cam?....440-2 intake, 2.25" hdrs, 727, 4.10 dana, caltracs/mono's, 10x29's bias.
Motor has been dyno'd twice,
with 850DP =714hp/742ftlbs rpm's?
with his 950DP =691hp@5700/724ftlbs@4000, 1.9vac on WOT...the dreaded 950 carb!.
They tried a 1050 Dom as well and it only made another 3hp more, lots of variables on dyno time/tuning, prob not much, but it deff needs a bigger carb. I was looking at either a QF1050 4150 (1.75" bores)or a 1050-1150 Dom+adapter if we have room with current 6-pk scoop, going to run it as is to start to get a base but I know it can run better without that 950. Other considerations later will be a better cam to use the heads more, comp won't change.
thanks.
thanks.
