Poly 318 tune up specs?
gtxdude
3:33 PM
Bloomington, MN
This is driving me crazy! I need to check out timing on 63 Fury with poly 318 and can't find tune up specs any where (I know there out there, just can't find them) Any one have that info? thanks
gtx,for my 1965 ,Automatic with a 2 bb it is 10dg,btc,and for a standard transmission 5dg,btc.i dont know if it would be different for a 1963.for me i just use a vacum gauge
hope this helps
Paul
Thanks Paul, I have a service manual and there's nothing in there or I haven't found it yet.
I have a 1964 original issue 318 poly spec card from Sun Electric with all the measurements, part numbers, timing specs and a lot more info on it. What is it exactly that you need?
Hi fwi, looking for tune up specs for 318 poly, mostly timing. I have seen 5 dg, btc for auto. Just trying to confirm it. thanks
63 Fury
My sheet says....
standard trans: 5 BTDC @ 500 rp
auto trans: 10 BTDC @ 500 rpm
dist. vac. line disconnected
Also have ignition advance at 2500 rpm numbers if you need them.
